A Motorola razr (2020) purchased from EE should come with an eSIM pack. If you don't have the eSIM don't worry, it's easy to order a new or replacement one.
How do I use an eSIM with the Motorola Razr?
In this article
The Motorola Razr (2020) doesn't accept a physical SIM, it uses a non-removable embedded eSIM instead. Setting up your eSIM is easy, just follow our guide.
How do I get an eSIM for my Motorola razr?
How do I set up an eSIM on my Motorola razr?
If you bought your Motorola razr directly from us, you'll be provided with an eSIM pack that contains a QR code to use for setup.
To set up with a QR code, first make sure you’re connected to the internet and then:
If you’ve ordered an eSIM for a SIM only plan with us, you’ll be able to download your eSIM from MyEE. Simply follow the instructions in your confirmation email. If you’re using the MyEE app, make sure you’re using the latest version and update it if not.
If you can’t use your old SIM, you’ll need to contact us so we can swap this over for you:
What if my eSIM QR code or Motorola razr camera is damaged?
Unfortunately, we can't support the manual entry of a QR code on the Motorola razr.
If you're having issues downloading your eSIM:
