Firstly, you'll need an iPhone SE or newer model on an EE pay monthly or SIM-only plan.
Here's a full list of devices that will work with the Apple Watch:
iPhone SE
iPhone 7 and iPhone 7 Plus
iPhone 8, iPhone 8 Plus and iPhone X
iPhone XS, iPhone XS Max, iPhone XR
iPhone 11, iPhone 11 Max, iPhone 11 Pro
No, your Apple Watch includes an eSIM. It's not a physical SIM and is instead automatically downloaded and activated as part of the set-up process, so don't worry – it's all ready to go.
To set up pairing, follow these steps:
open the Watch app on your iPhone
select the option to set up for myself and pair your new device
follow the steps in the app to get paired
If you're having difficulties setting up your Apple Watch via the app, try selecting cancel within the set-up and then try re-pairing to your iPhone.
Follow the below steps to unpair:
hold your iPhone and Apple Watch close together
go to the My Watch tab and tap your watch at the top of the screen
tap i next to the watch that you would like to unpair
tap Unpair Apple Watch
tap to confirm – you will need to enter your Apple ID password to complete the unpairing. The Apple Watch will now be ready to pair again
Yes, unpairing your watch won’t affect any active data plans you have. Just tap the option Keep Data Plan when you re-pair your Apple Watch to your iPhone.
Give us a call on 150 from your EE phone, or 07953 966 250 from a UK mobile or landline, and our dedicated Apple Watch team will be able to help
To set up a data plan, just use the Watch app.
You’ll need your EE login details, or you can register for an EE account today.
Then, simply:
the app will then take you through setting up your Apple Watch
select Set up Mobile Data
log in using your EE login details
select the Apple Watch plan and agree to Terms
That’s it!
Please allow up to 24 hours for your data plan to activate and show on your device.
Unfortunately, roaming is not available on the Apple Watch Personal Paired plan. However, you’ll still be able to use most of the features if it’s connected to your phone via Bluetooth.
