About eSIMs
Like a traditional SIM card, an eSIM stores the data your device needs to use the EE network. eSIM means an embedded SIM, but unlike a physical SIM card, an eSIM is built into your device.
It also enables multiple calling lines on a device that you can switch between. For example, one for work and one for personal use. It’s also secure - no one can remove the eSIM if your device is lost or stolen.
For the latest details on eSIM-compatible iOS devices, visit this Apple web page.
Get an eSIM
If you're new to EE and have ordered an eSIM with your new device directly from us, you’ll either:
- turn on your new device and follow the prompts to install your eSIM, or
- scan the QR code in the eSIM pack that was sent with your new device
If you've ordered an eSIM for a SIM only plan with us, follow the instructions in your confirmation email. You'll be able to download your eSIM by logging in to the EE website. or by downloading and opening the EE app on your device.
The lock status of your device is not affected by the use of an eSIM. For information about EE lock policy, please visit EE Device Unlocking.
Need to know
Currently, eSIM is only available to EE Pay Monthly customers.
Transfer a SIM or eSIM
If upgrading to a newer iPhone, you can convert your physical SIM to an eSIM or transfer your eSIM using SIM Transfer as part of the Quick Start set-up on your new iOS Device. The old and new devices must be on iOS 15.4 or above.
Using Apple Quick Start
- Turn on your current iOS device. Make sure it's connected to WiFi and has been updated with the latest iOS software. Make sure Bluetooth is turned on
- Place your new device next to your current one – check both are turned on
- Your new device will ask you to choose your language and country. Then, Quick Start will appear
- Follow Quick Start's instructions on how to transfer or convert your SIM.
For more information on Apple Quick Start, please visit this Apple web page.
Move from an Android to an iOS device
If you're a current EE customer and are switching to an iOS device from any other device and would like to use an eSIM. You can:
- Log in to EE and order a replacement eSIM (you’ll need your current SIM active to complete the activation – DO NOT delete or get rid of the old SIM before this). Go to Profile > Settings and permissions > Device and SIM > Replace my SIM/eSIM
- call 150 from your EE phone or 0800 956 6000 from an alternative line
- pick up an eSIM Pack by visiting an EE store with ID.
Download an eSIM on an iOS device
There are a few ways to get up and running with an eSIM.
You'll need an internet, or WiFi connection to get set up.
If you bought your new device from EE and selected eSIM, turn on your new device and follow the on-screen prompts during setup to download your eSIM.
If you’ve been sent an eSIM pack (which contains a paper QR code), scan it, and the information stored in it will allow us to safely and securely add the eSIM to your device.
To set up your eSIM:
- go into Settings > Mobile Data
- select Add Data Plan
- use your camera to scan the QR code on your eSIM pack, and once recognised
- confirm by selecting Add Data Plan
If you’ve ordered an eSIM for a SIM only plan with us, you can download your eSIM by logging in to EE. If you’re a new customer, you’ll need to register for an EE ID and link your product to download your eSIM. Follow the instructions in your confirmation email.
If you’re using the EE app, make sure you’re using the latest version and update it if not.
As part of the set up you'll be given the option to assign a name to each line and also choose what lines are used by default for data and calls and voice messages.
These can be easily changed later if you change your mind:
- go to Settings
- Mobile Data
- Default Voice Line / Mobile Data.
If you're using iOS 13 and later, both connections can be used for iMessage and FaceTime. This can be managed on your iPhone:
- go to Settings
- Messages
- Send & Receive
Lost or stolen device or deleted eSIM
If your iOS with an active eSIM, is lost or stolen, it’s essential to contact us and report it immediately. For more information and the best ways to let us know. visit this page: Lost or stolen mobile phone.
If you have deleted your eSIM, this does not cancel your plan. However, you'll need to order a replacement eSIM:
Using the EE app:
- download and open the EE app on your mobile
- select Manage
- select Mobile & SIMs
- scroll to the bottom of the page, select Check settings
- scroll down and select Replace my SIM/eSIM
- if you have more than one device on your account, select the correct device
- select eSIM, which you can download instantly.
- select whether you're adding to your current device or a new one
- follow the security steps, so we can verify your request
- we will then send you your eSIM and instructions
You can also request a replacement eSIM by phone, or by visiting your local EE store - please remember to bring your ID, or verify your ID in the EE app.
About Dual SIM
Dual SIM means that there are two SIM slots within the device - a physical SIM card and an eSIM.
With a Dual SIM device you can:
- have two phone numbers and two different plans on one device
- have two eSIMS, two physical SIMs or one of each
- get a local SIM plan while travelling abroad without swapping SIMs
(on unlocked devices) - have a plan on another network i.e. for your work number (only available on unlocked devices).
All iPhone models from the 2018 XS onwards are Dual SIM.
Get an eSIM for your EE plan
Or you can order a replacement SIM:
- log into the EE website and request a new SIM, or
- contact us by phone
- pop into a local EE store - please take a form of ID, or verify your ID in the EE app before you go
Using an eSIM iOS device on EE's network
If you bought an unlocked eSIM only iOS device, you can activate it on the EE network by taking out a SIM Only plan by selecting an eSIM as part of our Best SIM Only Deals and Pay Monthly SIM Contracts.
Can't use the QR code?
No worries, you can manually add the information contained within the QR code if it's damaged:
- when the Scan QR Code screen is open
- use the option to Enter Details Manually
To get your unique Activation Code and the address to input, log in to EE online. If you have an eSIM Pack, the code will be on the pack
Please note: You'll also see a Confirmation Code field - this is not required and should be left blank.
Using an EE eSIM abroad
You can use your eSIM in the same way you would a physical SIM. You can check what is included or any roaming charges by visiting our roaming calculator.
Always check before you travel.
Recognising which line calls are on
Initially, all your contacts will be assigned to the line you chose as your default voice line during set up. If you want to change this, there is an indicator within each contact that gives you the option to change which line you use for that contact.
If you're just entering a phone number straight into the dialler, you'll be able to select which line you call that number from in the options on screen.
For incoming calls, there is an indicator to show which line you're receiving the call on. The indicator is the first letter of the name you assigned to each line - for example, if your labels are called Personal and Business, the call indicator would be a P or a B.
Using data when on a call
If you're taking a call on the line that's not the same as your default data line then data won't work unless you turn on Mobile Data Switching.
This can be accessed on your iPhone through Settings > Mobile Data > Mobile Data Switching and will automatically switch lines for mobile data when you're on a call.
Or, follow the steps in our Device Guides.
