Download the EE TV app from your device’s app store if you haven’t already. Then you can:
How do I use Search with EE TV?
- Go to section
It's quick and easy to find something to watch on your EE TV box. Search by programme name to find programmes on now, coming soon and stored in your recordings and Replay.
And using your EE TV app you can even move programmes straight from your search results to your TV screen with a simple flick of your finger.
Search on your tablet
- open your EE TV app and tap the search button (in the top right-hand corner)
- enter the programme you want – you can type it in or use Siri if you've got an iPad
- the app will make suggestions for programmes available – tap the one you want and press SEARCH
If your programme is on now, you can choose to watch live content. To do this:
- tap to open the Show menu and select Live
- your search results will update to show programmes on now
- select the programme you want to watch
Watch recorded and Replay content
- open the Show menu and select Recordings (or Replay)
- if a few episodes are available you'll see Programme Details – choose the episode you want and press play
You can also use Search to look for programmes coming up that you'd like to record.
- open the Show menu and select Coming Soon
- select the programme you want to record
- in Programme Details, choose the episode you want
- tap the record button and choose to record the series or just this episode
You can also search for programmes coming up that you'd like to set a programme reminder for.
- tap the programme reminder button
Search on your phone
- open your EE TV app and tap the more button (in the top right-hand corner), then search
- your search results will show programmes on now
- select the programme you want to watch and press play
- search for the programme you want to record
- tap the Record button and choose to record the series or this episode
- search for a programme
- tap the programme reminder (bell) button
Search with your EE TV remote
- press MENU on your EE TV remote
- go to SEARCH and press OK
- enter the programme you want using the keypad on your remote e.g. number 1 three times for letter C, number 2 twice for E etc
- if you need the same letter twice, just pause between presses
- if you make a mistake, press the delete button
- EE TV will make suggestions for programmes available – choose the one you want and press SEARCH
Recording programmes from search
- in the top menu, go to COMING SOON or REPLAY, then highlight the programme you want to record
- press REC on your remote
- choose to record the series or record this episode, then press OK
- press MENU and go to COMING SOON
- select the programme you want and press OK
- highlight the programme reminder (bell) button and press OK
Sorting your search results
If search brings back lots of results, sorting your content can help to find the programme you want.
- highlight Sorted by and press OK on your remote
- from here, you can sort your content by:
Programme type
Alphabetically
Channel
Category
You can also use the Show menu to display:
- All content
- Coming soon
- Recordings
- Replay
- Live
- Hidden content
25p per call on pay as you go
Sat to Sun
Was this article helpful?
Thank you.
Glad to hear it.
Thank you.
Glad to hear it.
