Home Hotspot Frequently Asked Questions
  • Go to section
My Home Hotspot has lost its connection and the Data light is off. How can I reconnect?
Before trying to reconnect your extender to your home set up, first try switching it off and back on again to see if this resolves the issue. If the data light still hasn’t come back on after a couple of minutes, follow these simple steps:
  1. 1
    Make sure your Broadband Extender or Home Hotspot is plugged directly into a power socket
  2. 2
    Press the Link button on the extender for five to eight seconds. Wait for the power light to go back to steady green
  3. 3
    Once you’ve done that, press the Link button again, this time for one second.
  4. 4
    Within two minutes, press the Link button on one of the Broadband Extenders already in your home for one second to complete the connection to the network. The power and data lights should come on, indicating you’re now connected.
How many Broadband Extenders or Home Hotspots can I connect on a single network?
You can connect up to 16 Broadband Extenders on a single network. Only eight can be active at any one time.
I have a problem with my Broadband Extenders - how do I reset them?
If your Broadband Extenders stop working or become unpaired, you’ll need to reset them. To do this, firstly make sure the extenders are plugged into a power socket. On each extender, press and hold the Link button for more than 15 seconds before releasing. Wait a couple of minutes and the power lights on both will come on.
How can I check my Broadband Extender Kits are working?
Your extenders are designed to work together as a pair, and should work perfectly out of the box. To test them, find a double power socket and plug them in next to each other. After a couple of minutes, the power and data lights should come one, indicating you’re ready to go.
How can I change the settings of my WiFi Home Hotspot?
To change your settings, follow the simple steps below:
  1. 1
    Make sure you’re connected to your hotspot’s WiFi
  2. 2
    Go to http://mybtdevice.home
  3. 3
    Log in using your admin credentials (the default password is printed on the settings card at the back of your hotspot)
  4. 4
    Navigate to the relevant menu to change settings where required
Give us a call
Give us a call
Call now
150
Free to pay monthly
25p per call on pay as you go
Open
Closed
Mon to Fri
Sat to Sun
Ask the Community
Ask the Community
Ask questions and share tips with other people 24 hours a day
Find a store
Find a store
Something went wrong. Please try again later We cannot identify your location. Please enter your postcode below
Finding you
Open Mon to Sat
Open Sun
Need more help
Last updated: 17/10/2018
Darren posted this article. Got a comment? Good or bad, we'd be pleased to hear from you.
Was this article helpful?
  • Select a reason
  • The article is too long
  • The article doesn't make any sense
  • Other Reason
0/600
Thank you.
Glad to hear it.
Thank you.
Glad to hear it.
What is a WiFi booster?
How do I rename my WiFi Home Hotspot to match my WiFi network?
