How do I connect a Nintendo Wii to my wireless router?
  • Go to section
To connect a Nintendo Wii to your router, follow the steps below.
1.    Go to your Wii console's main menu
2.    Click the Wii button in the lower left corner
Wii console main menu
3.    Click Wii Settings
Settings option in Wii console menu
4.    Click the right-facing arrow
arrow command in Wii console menu
5.    Click Internet
Internet option in Wii console menu
6.    Click Connection Settings
 Connection Settings option in Wii console menu
7.    Select a connection indicated as None. In the example below we choose Connection 1
Connection 1 option in Wii console menu
8.    Click Wireless Connection
Wireless Connection option in Wii console menu
9.    Click Search for access point
Search for an Access Point option in Wii console menu
10.    The Wii console will search for an access point
Wii console searching for access point message
11.    Click OK
OK button on Wii console menu
12.    Your router will appear in the list of available wireless networks
Wii console available wireless networks list
13.    Click to select your router
14.    Click on the Input the password or key field
Wii console wireless password input screen
15.    Click to enter each character of your security key
16.    Click OK
Wii console on-screen keyboard
17.    Click OK
Wii console menu OK button
18.    Click OK to save settings
Wii console save settings message
19.    Click OK to start a connection test
Wii console wireless connection test message
20.    The Wii console will check if it's connected to your router
Wii console testing connection message
21.    If the connection test is successful, internet setup is complete and your Wii console is connected
Wii console connection test successful message
22.    Finally, choose if you'd like to update your Wii console. If you would, click Yes and follow the onscreen prompts
Give us a call
Give us a call
Call now
150
Free to pay monthly
25p per call on pay as you go
Open
Closed
Mon to Fri
Sat to Sun
Ask the Community
Ask the Community
Ask questions and share tips with other people 24 hours a day
Find a store
Find a store
Something went wrong. Please try again later We cannot identify your location. Please enter your postcode below
Finding you
Open Mon to Sat
Open Sun
Need more help
Last updated: 4/7/2018
Andrew posted this article. Got a comment? Good or bad, we'd be pleased to hear from you.
Was this article helpful?
  • Select a reason
  • The article is too long
  • The article doesn't make any sense
  • Other
0/600
Thank you.
Glad to hear it.
Thank you.
Glad to hear it.
Rename Your WiFi Network for Home Hotspot
How do I connect a Smart TV to my wireless router?
