How do I connect an Apple Mac to my wireless router?
  • Go to section
Getting started
Getting started
To connect using wireless, you'll need your router's wireless network name and wireless password. You'll find these printed on a sticker on the bottom or back of most routers, as seen in the example below.
Router sticker
It can also help to:
  1.
    move close to your router while setting up the connection
  2.
    unplug an Ethernet cable (if you've already set up a wired connection)
How do I connect to my router?
To connect an Apple Mac to your router, follow the steps below.
1.    Click on the AirPort icon in your Mac's menu bar
AirPort icon in Mac menu bar
2.    A list of wireless networks will be shown in the network list
3.    Select your wireless network. In the example below, ours is 5GHz-EE-1a2b3c - you'll find yours printed on your router
4.    If you can't see any wireless networks, try moving closer to your router and checking it's turned on
Mac network list
5.    You'll be prompted to enter your password - this is your wireless password, which you'll also find printed on your router
6.    It may help to select the Show password option, so you can see what you're typing
Mac wireless password entry screen
7.    AirPort will connect to your router
Mac
8.    Wait a few seconds - the AirPort icon will change to black (or black and grey)
AirPort icon activated on Mac
Error after entering your security key?
If you get an error while trying to connect:
  1.
    try setting up the connection again, checking you're entering your security key correctly. You'll need to enter the dash (-) if you have a Bright Box router
  2.
    restart your router and computer, then try to set up the connection again
Exclamation mark in the AirPort icon?
If you're connected to your router, but are unable to view web pages or use the internet you may see an exclamation mark inside the AirPort icon.
See one of our guides below to check if there's a problem with your broadband connection.
  1.
    EE Smart Hub
  2.
    Bright Box 2 Wireless Router
  3.
    Bright Box 1(R) Wireless Router
  4.
    Bright Box 1 Wireless Router
  5.
    4GEE Home Router
  6.
    Technicolor TG589 Router
  7.
    Livebox
Give us a call
Give us a call
Call now
150
Free to pay monthly
25p per call on pay as you go
Open
Closed
Mon to Fri
Sat to Sun
Ask the Community
Ask the Community
Ask questions and share tips with other people 24 hours a day
Find a store
Find a store
Something went wrong. Please try again later We cannot identify your location. Please enter your postcode below
Finding you
Open Mon to Sat
Open Sun
Need more help
Last updated: 4/7/2018
Sharelle posted this article. Got a comment? Good or bad, we'd pleased to hear from you.
Was this article helpful?
  • Select a reason
  • The article is too long
  • The article doesn't make any sense
  • Other
0/600
Thank you.
Glad to hear it.
Thank you.
Glad to hear it.
How do I set up a wireless connection on my Amazon Kindle?
How do I use my own router for home broadband?
