What are my home broadband internet settings?
  • Go to section
This guide will help if you're looking for your broadband internet settings. You'll find everything you need to set up your own router and log in to your account.
What is my broadband internet username?
Your broadband username will look similar to one of the following examples:
  1.
    PRODUCTIONHQNUN123456@fs
  2.
    yourname.wanadoo.co.uk@fs
  3.
    yourname.freeserve.co.uk@fs
  4.
    yourname.fsnet.co.uk@fs
  5.
    yourname.fsbusiness.co.uk@fs
  6.
    yourname.fslife.co.uk@fs
  7.
    yourname.fsworld.co.uk@fs
Good to know
Your EE router is set up just for you, so in most cases you don't need to know your router's username. We'll automatically set it up after you've selected your parental control options
If you need your broadband username to set up your own router, set up your Bright Box first – you'll then find your username on the Bright Box status page or you can contact us for more help.
Got your own router?
If your username is readytoconnect@fs, follow our step-by-step guide to setting up your own router
What is my internet password?
yourname.nodename.co.uk@fs
If your username looks like yourname.nodename.co.uk@fs, you chose your password when first signing up for the service. Remember, passwords are case sensitive.
Don't forget
If you've changed your password to access your account online, please continue to use your original password to connect to the internet
If your username looks like PRODUCTIONHQNUN123456@fs, your password will look like HQNPASS123456. Simply replace the numbers in the password, with the ones found in your username.
Don't worry
Broadband usernames in this format can't be used to access your account online or email. They're simply used to connect your router to the internet
What are my advanced internet settings?
When setting up your router, you may be asked to enter advanced settings. To help you, we've listed some of the more common ones below.
IP address
  1.
    your IP address is allocated dynamically via DHCP. We're unable to offer a static IP address
Encapsulation
  1.
    PPP over ATM for standard broadband
  2.
    PPP over Ethernet for fibre broadband
Multiplexing method
  1.
    VC-Based
Virtual circuit
  1.
    VPI=0
  2.
    VCI=38
Modulation
  1.
    Multi mode
Authentication
  1.
    CHAP
MTU (maximum transmission unit)
  1.
    in case of problems with a third-party router, change MTU to 1492
Give us a call
Give us a call
Call now
150
Free to pay monthly
25p per call on pay as you go
Please note: lines close at 8pm on
Good Friday (April 19)
Easter Monday (April 22)
Open
Closed
Mon to Fri
Sat to Sun
Ask the Community
Ask the Community
Ask questions and share tips with other people 24 hours a day
Find a store
Find a store
Something went wrong. Please try again later We cannot identify your location. Please enter your postcode below
Finding you
Open Mon to Sat
Open Sun
Need more help
Last updated: 5/7/2018
Nikki posted this article. Got a comment? Good or bad, we'd be pleased to hear from you.
Was this article helpful?
  • Select a reason
  • The article is too long
  • The article doesn't make any sense
  • Other Reason
0/600
Thank you.
Glad to hear it.
Thank you.
Glad to hear it.
Can I claim an Early Cancellation Credit from EE?
What are EE’s Fibre Max 1 and Fibre Max 2 Broadband plans?
