A 5GEE WiFi plan which will include a 5GEE WiFi device and access to our 5G network.
What is 5GEE WiFi?
In this article
5GEE WiFi allows you to create your own WiFi hotspot using our 5G network.
What plan do I need for 5GEE WiFi?
How do I manage my 5GEE WiFi account?
You can manage your account online or through the My EE app where you'll be able to change your account settings, check your data allowance and usage or buy add-ons.
Do I still get access to 4G on a 5GEE WiFi plan?
Yes, 5G doesn't replace 4G - both networks will work together so you'll still be able to access our 4G network where you need to on a 5GEE WiFi plan.
Can I buy a data add-on with a 5GEE WiFi plan?
Yes, you can buy a data add-on if you run out of data. If you're on a 5GEE WiFi plan and use our 5GEE WiFi device, data add-ons will give you access to 5G speeds.
To buy a data add-on:
Can I use a 4GEE WiFi plan with a 5GEE WiFi device?
Yes but you won't have access to our 5G network and 5G speeds - you'll only be able to access our 4G network. To connect to our 5G network you'll need a 5GEE WiFi plan.
Can I gift data on a 5GEE WiFi plan?
Yes, you can gift your data allowance on 5GEE WiFi plans.
