BT Sport on EE
In this article
You can add the BT Sport app as a chargeable standalone add-on to your pay monthly or SIM only plan or as a Swappable Benefit if you have a 5G Smart or Smart plan.
How can I watch BT Sport with EE?
You can watch BT Sport on your TV or through the BT Sport app.
How do I get the BT Sport app?
To add the BT Sport app to your plan as a chargeable standalone add-on:
  1.
    log in to My EE or use the My EE app
  2.
    go to Menu > Plans, Swappables & add-ons
  3.
    select Add-ons and follow the steps to add the pass to your plan
  4.
    or text SPORT to 150
Or select the app as your Swappable Benefit if you have an eligible Smart plan.
  1.
  2.
  3.
    select Swappables and follow the steps to select the pass
  1.
    cast from your device to your TV using Apple TV or Google Chromecast
  2.
    visit sport.bt.com on your laptop and log in with your BT Sport ID - you’ll then need a HDMI cable to connect your laptop to your TV
How do I set up the BT Sport app?
You'll need a BT ID username and password to log into the BT Sport app.
> Find out more about how to set up the BT Sport app
How can I watch the BT Sport app on multiple devices or a big screen?
There are a number of ways to watch BT Sport on a big screen. You can download the BT Sport app on one of the devices below and then log in using your BT Sport ID.
  1.
    an Apple TV 4th Generation and above
  2.
    a Samsung Smart TV 2015 models or later
  3.
    a Xbox One, Xbox One X and Xbox One S
Alternatively you can:
  1.
  2.
How do I cast the BT Sport app to a big screen?
If you’ve got BT Sport casting then find out how to cast to your big screen. You'll need either Apple TV or Google Chromecast to be able to cast to your TV.
Good to know:
You can only cast from the Standard Player within the BT Sport app - the Enhanced Player does not support casting.
How do I cast on Apple TV?
  1. 1
    set your TV to the correct HDMI input (the HDMI port your Apple TV is plugged into)
  2. 2
    access your Apple TV app as normal on your iPhone or iPad
  3. 3
    find the event you want to Airplay and click on it to start streaming on your device. When you’re presented with the option of ‘standard’ or ‘enhanced’ player, choose ‘standard’
  4. 4
    tap the ‘Airplay’ icon in the bottom-right corner of the video player
  5. 5
    select ‘Apple TV’ on the menu that appears and the video will then start Airplaying to your TV
  6. 6
    if you want to stop Airplaying, click on the blue ‘Airplay’ icon
  7. 7
    when you’re presented with the menu, click on your device. This will stop the video Airplaying on your TV and playback will resume on your device
Getting sound but no video?
If you're experiencing issues with casting on Apple TV, like getting sound but no video, then follow Apple's troubleshooting guide.
How do I cast with Google Chromecast?
  1. 1
    download the Google Home app and set up your Google Chromecast
  2. 2
    set your TV the correct HDMI input (the HDMI port your Google Chromecast is plugged into)
  3. 3
    make sure your Google Chromecast is set up to the same wireless network as your iOS or Android device
  4. 4
    select the casting icon in the top right corner of the app screen (if you don’t see the casting icon and you use an Android device, please make sure your Google Play Service is up-to-date)
  5. 5
    you’ll then get a pop-up window showing all Google Chromecast devices detected and you can select the Google Chromecast device you want to connect to
  6. 6
    once connected the icon will turn white which means you’ll cast that device when play the video
How do I fix issues with the BT Sport app?
Don't worry!
If you're having issues using the BT Sport app, we're here to help.
How do I fix BT Sport error code ID003 or other error codes?
Operator error?
Get advice on how to fix error codes you may encounter in the BT Sport app.
How do I cancel my BT Sport subscription?
You can cancel your BT Sport add-on by:
  1.
    texting STOP SPORT to 150
You won’t be charged for this within your free period.
You will then be asked to either:
  1.
    text STOP LARGE or STOP BIG SCREEN to stop your large-screen service and keep BT Sport access on your mobile only
  2.
    or text STOP SPORT to stop both the BT Sport app and BT Sport large-screen service
Please note: if you cancel the app after your three-month free offer has ended, you’ll pay for the BT Sport service up until your next bill date.
Thanks for your feedback
Give us a call
Give us a call
Call now
150
Free to pay monthly
25p per call on pay as you go
Open
Closed
Bank Holiday Monday opening times: 08:00-20:00
Mon to Fri
Sat
Sun
Ask the Community
Ask the Community
Ask questions and share tips with other people 24 hours a day
Book an appointment
Book an appointment
You can book a phone appointment with one of our local experts.
Something went wrong. Please try again later We cannot identify your location. Please enter your postcode below
Finding you
Open Mon to Sat
Open Sun
Need more help
