If you see the ID003 error code while using the BT Sport app, this means that access to the BT Sport app isn’t active on your account. Try these steps to fix the issue:
How do I fix BT Sport error code ID003 or other error codes?
- Go to section
Get advice on how to fix error codes in the BT Sport app.
ID003 error code
ID003 error code
DO NOT try to create another BT ID username and password while you're seeing this error code – it may cause further problems.
Step 1
You need to ensure you've set up your BT ID:
Step 2
If you've never had a BT ID, you'll be asked to set one up and create a password. You can use this BT ID to log in to the BT Sport app about 10-15 minutes after sign-up.
Step 3
If you already have a BT ID (this will be your email address), you'll not be asked to create a password in the sign-up process for the BT Sport app. Instead you'll receive an email from BT with instructions to link the BT Sport app to your existing account.
Once you've followed the instructions in the email, you'll need to wait at least 10-15 minutes for your BT Sport account to fully activate before you can log in to the app. Your BT Sport account may take up to 24hrs to activate, so please be patient.
Step 4
If you've followed the steps above and you're still seeing this error message appear, you'll need to call us as there may be a problem with your account:
Step 5
If you’ve already had access to the BT Sport app but are now seeing this error code, your EE billing account may have been suspended or cancelled. You'll need to:
If you've forgotten your BT ID password, you can retrieve or reset it through the BT Sport app or by visiting the BT website.
CF001 or CF002 error code
These error codes are normally caused by app configuration issues. Try closing the app and opening it again. If this doesn't work, uninstall the app and reinstall it again.
NCE-001 error code
NCE-001 error code
This error code means that you've already registered for BT Sport in the past or your EE mobile number is linked to another BT account. You may also see this error code when porting a BT mobile number over to EE and the transfer hasn't completed yet.
If you think you've successfully set up your BT ID, try logging in to the BT Sport app.
If the BT Sport app doesn't work:
NCE-003 error code
NCE-003 error code
This error will show if you've requested a validation PIN too many times. You'll need to wait until the next day before you can request a new validation PIN again.
If you don't receive a validation PIN, make sure you've entered the correct phone or tablet number in the first step of the set-up process. If you still don't get a PIN:
If you receive your validation PIN but it's not approved, you'll need to make sure your browser isn't timed out. If you're still experiencing problems then open a separate browser on another device and set up your BT ID again by taking the link we sent you via text message and putting it directly into the address bar of your browser.
NCE-004 error code
NCE-004 error code
This error means the number you entered in the first step of the set-up process wasn't recognised as a valid EE phone or tablet number. Please check that you're entering the correct EE phone or tablet number and begin the set-up process again.
NCE-005 error code
NCE-005 error code
Your BT ID hasn't finished linking to your BT Sport service which means it's not ready for you to use yet. Please be patient and try the BT Sport app again shortly.
If you haven't added BT Sport to your account:
NCE-006 error code
NCE-006 error code
This indicates that your EE account may be suspended or cancelled.
If this is the case, you'll need to speak to EE directly:
VC001 or VC024 error code
These error codes normally appear when you're trying to watch live channels or videos via the BT Sport app. Try logging out of the app and then logging back in again.
This will clear any previous sessions and should fix the problem.
VC005, VC013 or VC014 error code
These errors appear when you're trying to watch a video or channel in the BT Sport app. Playing the video or channel again will usually fix this but if not you can:
If you see the error code VC005, you'll need to ensure all clock settings on Apple iOS devices are set to default 24-hour time. To set your clock settings:
VCO11 error code
VCO11 error code
This error code can mean there's a problem with accessing the BT Sport channels or with playing back a video in the app. This may be caused by a problem with your device and WiFi connection or because you're not fully logged onto a WiFi hotspot.
Error VC011 may also occur if you use data compression apps. We recommend that you try uninstalling any data compression apps you have on your device.
Errors starting (diva_error_...)
These errors appear if your WiFi or mobile connection isn't fast enough to load the enhanced video player. Please check your WiFi or mobile connection then try again.
‘There are no events to show’ error message
This error message will show on Apple iOS devices.
If this error shows and there are no programmes in the "Watch Now" part of the BT Sport app, you'll need to ensure all clock settings are set to default 24-hour time:
If you're streaming via 3G, you'll need to enable mobile streaming with the BT Sport app settings. You can find Settings in the main menu of the BT Sport app.
Mon to Sun 8am - 11pm
25p per call on pay as you go
Sat
Sun
Was this article helpful?
Thank you.
Glad to hear it.
Thank you.
Glad to hear it.
