EE smart number technology allows you to use your mobile phone number to make and receive calls and texts on up to five of your Apple devices such as the:
In this article
We're now making it even easier for you to make and receive calls and texts on your number, even when you don't have your iPhone.
What is EE smart number technology?
Who can use EE smart number technology?
Pay monthly and small business customers with an iPhone 6 or newer.
How do I set it up?
How do I set it up?
You can easily set it up on your iPhone by following these simple steps.
Can I make calls on WiFi with EE smart number technology?
Yes you can, as well as use our award winning 4G network.
What devices can I use with EE smart number technology?
You can use all the devices below - just make sure you have updated to the latest version of iOS.
iOS |
Device |
Your main device |
iOS 11.3 and later |
iPhone 6 and later | |
iOS 10 and later (though we recommend using devices that support iOS 11) |
iPad Air and later |
Your paired device
iPad Mini 2 and later |
iPad 4 and later |
iPad Pro 2016 and later |
iPod Touch 2017 5th Gen / 6th Gen and later |
OS X El Capitan |
MacBook Air (2012 and later) |
MacBook Pro (2012 and later) |
iMac (late 2012 and later) |
Mac Mini (late 2012 and later) |
Mac Pro (late 2013 and later) |
iMac Pro |
watchOS 2 or later |
Apple Watch Series 1 and later |
How much does it cost?
It’s free and part of the many benefits of being an EE customer.
Can I use EE smart number technology with my current phone number?
Yes, your mobile phone number will not change – it just means you can use it across any of your compatible Apple devices.
How many devices can I use?
You can use up to five Apple devices.
Can I start a call on one device and transfer it to another?
Yes, you can start a call on one of your paired devices like your iPad and transfer it to your iPhone whenever you need to by making sure the correct setting is on in your device settings.
Will I get charged for calls on my paired devices?
Depending on the type of calls you make, you will either be charged at the rate on your mobile plan or it will come out of your allowance.
Will using EE smart number technology on my paired devices use up my data allowance?
If your paired device is on a EE data plan, then you don’t need to worry about your data being used as it doesn’t use data on the EE network. But if you’re using our smart number technology on another network, or on WiFi, it will use a small amount of data like 10MB for a 30 minute call.
Can I use EE smart number technology while I’m abroad?
No, as WiFi calling isn't available when you’re outside of the UK, but if your paired devices are still in the UK, they will ring as normal when your phone is called.
What happens if someone else uses EE smart number technology on one of my paired devices to make calls?
If they make calls to premium rate or international numbers, you’ll be charged at our standard rates and charges on your next bill.
