I updated my device's operating system and now the EE Home app isn't working. What should I do?
In this article
You might have noticed some issues with your EE Home app after updating to iOS 14 or Android 10. Here you’ll find what causes the issues and how to fix them.
What has changed?
What has changed?
Every device that communicates using wi-fi has a MAC (media access control) address. This is a unique number that allows devices to identify each other on a wi-fi network.
Apple and Google have added a new feature to iOS 14 and Android 10 which generates a new MAC address for the device when it connects to a wi-fi network, including your home network.
This randomisation happens automatically, and you cannot opt-in or out. It might cause some issues in the EE Home app.
My wi-fi access controls are not working after the update. What should I do?
If you've updated any of your devices to iOS 14 or Android 10, you should be able to connect to your EE home network as normal without having to enter your network password. But you might notice that your groups or wi-fi access controls aren't working.
This is because the EE Home app sees your device's new MAC address and thinks it's a new device. So any wi-fi access controls set up previously - such as those set up to determine when children can use home wi-fi - will no longer work.
To fix this, you need to set up your wi-fi access controls again. If you created a group of devices previously, you'll need to add your device to the group again.
My device is not listed with the custom name I gave it. What should I do?
You might notice that your devices listed in the Connected devices area of the app have generic names like 'iPhone' or 'Pixel 3' instead of any custom names previously set. To fix this you need to rename your device.
In EE Home under Your offline devices you'll find all devices that have been connected to your wi-fi network but aren't connected now. You might see the device you're using listed under an old name. This is just the listing for the old MAC address for your device, so you can ignore it.
Where can I find my device's MAC address?
If you want to check the MAC address of your device, go to Connected devices and tap the device. The MAC address is a series of numbers and letters.
I cannot manage Smart Wi-Fi in the EE Home app after updating my device. What should I do?
If you have a device running on iOS 14 and use the EE Home app to manage Smart Wi-Fi you'll see a permission notification when you open the app. If you refuse permission by selecting 'Don't allow', you won't be able to use or manage Smart Wi-Fi within the app. If you have granted permission by selecting 'OK', everything will work as expected.
If you've already clicked 'Don't allow', you need to allow permissions:
Either
Go to Settings > EE Home > Local network and toggle to change the permissions of the app
Or
Go to Settings > Privacy > Local network > EE Home and toggle to change the permissions of the app
Thanks for your feedback
Ask the Community
Ask the Community
Ask questions and share tips with other people 24 hours a day
Book an appointment
Book an appointment
You can book a phone appointment with one of our local experts.
Something went wrong. Please try again later We cannot identify your location. Please enter your postcode below
Finding you
Open Mon to Sat
Open Sun
Need more help
