Just visit the Add To Plan accessories page and select the product you’d like to buy. It will let you know if the product works with Android or iOS.
How do I choose and use Smart Home products?
In this article
Need to find out more about Smart Home products at EE? Take a look below for more information on choosing the right Smart Home product, when it will be delivered and what to do if there's a problem with your product.
How do I check if my Smart Home product will work with my smartphone?
How do I check if my Smart Home product is compatible with my digital assistant?
Just visit the Add To Plan accessories page and select the product you’d like to buy. It will outline if it's compatible with Amazon Echo, Google Home and/or Apple HomePod.
How do I buy a Smart Home product?
You can buy more Smart Home products on Add To Plan accessories page but if you're happy to pay for your product all in one go, then visit our accessories shop.
Add To Plan lets you buy new Smart Home products and spread the cost across your monthly EE bills over the next 11 months.
When will I receive my Smart Home product?
If you buy a Smart Home product online or over the phone, we'll tell you about delivery times at point of sale.
If you buy your Smart Home product at the same time as a phone, both items will be delivered at the same time. However if a phone is in a pre-order period when you order, your Smart Home product won't be dispatched until your phone is in stock.
There’s a problem with my Smart Home product
All EE Smart Home products come with 12 months free helpline support. If you’re experiencing problems our experts can help you with troubleshooting, set-up and connecting your Smart Home product to your network and to other devices.
Alternatively, download the Smart Home Help app for an even quick service.
