If you’ve bought a Nest Learning Thermostat or a Nest Thermostat E with installation, it will be installed by AXA. To book your installation you'll need to:
How do I set up my Nest smart thermostat?
In this article
Need help booking your thermostat installation? Find all the details you need here.
How do I book my thermostat installation?
You have 30 days to book your smart thermostat installation appointment after purchase but we recommend you book it within 14 days.
The Nest Learning Thermostat does not include a power cable and is only suitable if you're planning to wall mount your thermostat.
If you're planning to place your thermostat on a surface you'll need the Nest Learning Thermostat stand with inclusive power cable.
The Nest Thermostat E comes with a built-in stand and can either be wall mounted or placed on a surface.
How do I cancel or change my installation date?
AXA will be in touch within 24 hours to confirm your appointment. You can then use this number to change or cancel your appointment.
How do I return my thermostat?
If you bought your Nest smart thermostat with installation:
If you bought your Nest E Thermostat with self-installation:
There’s a problem with my thermostat
All EE Smart Home products come with 12 months free helpline support. If you’re experiencing problems our experts can help you with troubleshooting, set-up and connecting your Smart Home product to your network and to other devices.
Alternatively, you can get further support from the manufacturer directly.
