How to change your WiFi password
The first time you pair to the app you’ll be prompted to change your password. If you do it then you can do it any time by going intosettings > camera and then change WiFi password. Or follow the additional steps below:
  1. Select change WiFi password.
  2. Enter the current WiFi password.
  3. Enter the new password (you'll also need to re-enter this to confirm).
  4. Reconnect to the camera - to do this, exit the app and enter the WiFi settings of your mobile.
  5. Select 4GEE Action Cam and select forget.
  6. Then re-select 4GEE Action Cam and select connect.
  7. Enter your new password then once connected go back to the app.
Don’t forget that if you decide to reset your settings back to default, this will also reset your new WiFi password. You’ll then have to follow steps 5-10 again but this time reverting to the original default password.
Last updated: 29/1/2019
Simon H posted this. Got a comment? Good or bad, we'd be pleased to hear from you.
Was this article helpful?
  • Please select a reason
  • I didn't understand the article
  • I found the information but it didn't resolve my issue
  • Please let us know how we can make it better
0/600
Great!
Thanks for your feedback
We'll use your feedback to keep improving our help articles
