How to update your camera software
To update your camera software, follow these steps:
  1. Turn on your camera.
  2. Check you have a 3G or 4G signal. You can do this by checking the bottom right corner of the camera screen.
  3. Scroll to settings and scroll to more.
  4. Enter more and scroll across to update.
  5. If an update is available it will appear and you need to download and then install the update.
Alternatively you can pair to the app and download the upgrade via the app. Select settings and camera update.
Last updated: 29/1/2019
Simon H posted this. Got a comment? Good or bad, we'd be pleased to hear from you.
Was this article helpful?
  • Please select a reason
  • I didn't understand the article
  • I found the information but it didn't resolve my issue
  • Please let us know how we can make it better
0/600
Great!
Thanks for your feedback
We'll use your feedback to keep improving our help articles
