You can buy the following accessories for your 4GEE Capture Cam from the EE accessories page:
- head strap
- chest mount
- bike mount
- adhesive mount set
- helmet mount
- vehicle mount
- surf mount
You'll need to use the accessory adaptor to attach any of these to your camera. The adaptor and a 'How to' guide are in your camera's box.
Once you've attached the adaptor to the back or base of your camera, you can connect it to the accessory and lock it into place.
To remove the adhesive mounts, you can use a hairdryer or heat gun to soften the adhesive and slowly peel back.
Please note: you won't be able to re-use an adhesive mount once you remove it.
Other tips:
- when using surf boards and the surf mount, don't mount to soft-top boards as they are porous and the mount will not adhere properly
- when using adhesive mounts on helmets, don't mount to textured surfaces as the mount may not adhere as well
- we don't recommend using adhesive mounts on skis or snowboards as the flex and vibration caused can sometimes lead to the mount coming loose.
Failure to follow these guidelines may result in loss or damage of your camera which is not covered under warranty.
