Buying a data add-on
If you're a pay monthly customer
As a pay monthly customer you’ll get a bill every month. Your inclusive data allowance lasts 30 days and resets every month.
If you run out, you can buy a data add-on until your next inclusive data allowance starts. Here's how:
  1. Connect your phone to the 4GEE Capture Cam WiFi.
  2. Turn on your 4GEE Capture Cam.
  3. On your phone, open the WiFi settings, select 4GEE Capture Cam from the list of available WiFi connections and enter the default password that can be found in the Quick Start Guide or 'Keep Me' card in your box.
If you're a pay as you go customer
You'll need to activate your free 2GB data SIM. To do that, follow these easy steps:
  2. On your phone open the 4GEE Capture Cam app.
  3. Select settings and then your account.
  4. Select data management.
  5. Choose the data add-on that you’d like to buy. If you don’t have enough credit to buy the add-on you'll need to top up first.
Once you’ve activated your SIM you may have to wait up to an hour before being able to set up Facebook Live and stream live.
Last updated: 29/1/2019
Simon H posted this. Got a comment? Good or bad, we'd be pleased to hear from you.
Was this article helpful?
  • Please select a reason
  • I didn't understand the article
  • I found the information but it didn't resolve my issue
  • Please let us know how we can make it better
0/600
Great!
Thanks for your feedback
We'll use your feedback to keep improving our help articles
