Any time after that, you can top up using the 4GEE Action Cam app (this is compatible with your 4GEE Capture Cam). Just follow these steps:
- Connect your phone to the 4GEE Capture Cam WiFi.
- On your phone open the 4GEE Action Cam app.
- Select settings and then your account.
- Select data management.
- Select the top up button.
- Follow the steps on screen to top up.
Or you can top up online or by logging into My EE.
