The device uses a Nano SIM card. Make sure you are using the correct size SIM card, as an incorrectly sized SIM card may become stuck in the device.
What size SIM card does the device use?
Last updated: 30/1/2019
Simon H posted this. Got a comment? Good or bad, we'd be pleased to hear from you.
Was this article helpful?
Great!
Thanks for your feedback
We'll use your feedback to keep improving our help articles
