Connect using push button connect
When setting up a wireless connection, you may be given the option to push the WPS button on the router.
  1. Press and hold the WPS button on the router for five seconds - it will look like one of the options below:
    OR
  2. Alternatively, select Start PBC in WiFi Protected Setup settings
  3. The Intelligent Wireless light on the router will flash quickly
  4. The wireless software will connect to the router, and then obtain the required wireless settings to set up a secure wireless connection
Last updated: 8/2/2019
Was this article helpful?
  • Please select a reason
  • The article is too long
  • The article doesn't make any sense
  • Other Reason
0/600
Great!
Thanks for your feedback
We'll use your feedback to keep improving our help articles
Connect using WiFi Protected Setup (WPS)
Connect using the PIN method
