Connect and turn on your router
Connect the cables and turn on your router
  1. Plug the other end of the grey broadband cable into the DSL port on your router
  2. Connect the two parts of the power supply together
  3. Plug the power cable into the router
  4. Connect the power supply into a plug socket and turn it on
  5. You can now switch on your router
Check it over
Everything should now look like this - the Power light will go greenand the Broadband light will go green shortly afterwards.
Or if you have a dual socket it should look like this:
Broadband light flashing or off?
If the broadband light doesn't go solid green after a couple of minutes, check:
  • Broadband is live - We'll send you a text message the morning the service is due to go live, and another text and email when it does.
  • Your service could go live at any time up until midnight - you can track your order online from Your Account.
  • Your phone line is working OK - try plugging a phone into the same filter as your broadband and listening for dial-tone - if not, see our guide to fixing Home Phone faults.
If you're still having problems, see our guide Bright Box router - connection not working.
Last updated: 8/2/2019
Simon H posted this. Got a comment? Good or bad, we'd be pleased to hear from you.
Was this article helpful?
  • Please select a reason
  • I didn't understand the article
  • I found the information but it didn't resolve my issue
  • Please let us know how we can make it better
0/600
Great!
Thanks for your feedback
We'll use your feedback to keep improving our help articles
