Getting connected - wireless
To connect a computer or device to your Bright Box router, you'll need:
  • Your wireless network name (also called an SSID), e.g. EE-Bright-Box-xyhy
  • Your wireless password (also called a security key or wireless network key)
You'll find these on a sticker on the bottom of your router and on your KEEP MEE card:
To connect to your wireless network
  1. Check your wireless adapter is installed and turned on
  2. Open the wireless software on your computer or device
  3. Look for your wireless network name in the list of networks - use the one starting EE-...
  4. Select Connect or Join
  5. Enter your wireless password and connect
  6. Great - your device should now be connected to your Bright Box
Last updated: 8/2/2019
Was this article helpful?
  • Please select a reason
  • The article is too long
  • The article doesn't make any sense
  • Other Reason
0/600
Great!
Thanks for your feedback
We'll use your feedback to keep improving our help articles
Connect and turn on your router
Getting connected - wired
