When setting up a wireless connection, you may be given the option to push the WPS button on the router.
- Press and hold the WPS button on the router for five seconds - it will look like one of the options below:
OR - Alternatively, select Start PBC in WiFi Protected Setup settings
- The Intelligent Wireless light on the router will flash quickly
- The wireless software will connect to the router, and then obtain the required wireless settings to set up a secure wireless connection
