We released new firmware (software) for the Bright Box router in April 2015. There are no new updates planned.
Update Bright Box router
You don't need to do anything - we'll automatically update your router between the hours of 4am - 6am. If you turn your router off at night, you may like to leave it turned on. If not, don't worry - we'll also be updating routers during the day after a couple of weeks.
How do I know if the firmware is updating?
The update doesn't take long, so you probably won't even notice. At the end of the process, the router will re-start so you may lose your internet connection for a minute.
