Change security to WPA
You can change wireless settings to WPA2, WPA or back to the default WPA/WPA2 Mixed Mode settings from the router's admin pages. To do this:
  1. From a computer connected to your Bright Box, go to 192.168.1.1 (opens in a new tab or window)
  2. The router's LOGIN SCREEN will open
  3. Enter the username and password for the admin pages
    - The username is admin (all lower case)
    - The password can be found on a sticker on the bottom of your router
  4. Click LOGIN
  5. The STATUS page will open
  6. Select BASIC from the menu
  7. Select Wireless Settings
  8. The WIRELESS SETTINGS page will open
  9. In the security field, make sure WPA is selected
  10. In the WPA mode menu, you can choose the version of WPA you wish to use - default settings are WPA/WPA2 Mixed Mode
    - WPA/WPA2 Mixed mode is compatible with most operating systems
    - WPA offers increased compatibility with older operating systems, but is limited to 54 Mbps
    - WPA2 offers enhanced security, and up-to 300Mbps wireless n speeds and up-to 867Mbps wireless ac speeds on your internet network
    - If you're connected to the 5GHz network, you can also change 5GHz settings from the 5GHz menu
  11. Click SAVE SETTINGS
  12. Your new settings will be applied
  13. Refresh your wireless software and connect using the new security details
Last updated: 7/2/2019
Simon H posted this. Got a comment? Good or bad, we'd be pleased to hear from you.
Was this article helpful?
  • Please select a reason
  • I didn't understand the article
  • I found the information but it didn't resolve my issue
  • Please let us know how we can make it better
0/600
Great!
Thanks for your feedback
We'll use your feedback to keep improving our help articles
