Change wireless channel
Your neighbour's WiFi, computers, microwave ovens, baby monitors and all your lovely gizmos give off signals that can affect your wireless connection. Not good. Changing the channel or frequency on your Bright Box 2 can help fix the problem. There's a few solutions you can try:
Swap to 5GHz
Your Bright Box 2 supports both 5GHz and 2.4GHz wireless - sometimes called dual-band. 5GHz is (generally) less crowded, so you'll get less interference from other devices.
Swapping is easy - simply connect to the wireless network starting 5GHz-EE...
If you can't see the 5GHz-EE... network, try moving closer to your router, or consider upgrading your wireless device.
Intelligent wireless
When you turn on your Bright Box 2, it looks for and uses the best WiFi channel it can find. This helps reduce problems caused by interference, giving you the best wireless connection.
You can also re-check by pressing the Intelligent Wireless button. You'll find this on the top of your Bright Box 2.
Change your channel from the admin pages
You can also change your wireless channel from your Bright Box 2 admin pages. To do this:
  1. From a computer connected to your Bright Box, go to 192.168.1.1 (opens in a new tab or window)
  2. The router's LOGIN SCREEN will open
  3. Enter the username and password for the admin pages
    - The username is admin (all lower case)
    - The password can be found on a sticker on the bottom of your router
  4. Select LOGIN
  5. The STATUS page will open
  6. Select BASIC from the menu
  7. Select Wireless Settings
  8. The WIRELESS SETTINGS page will open
  9. From here, you can change the channel for your 2.4GHz and 5GHz wireless networks
2.4GHz network
Wireless network name starting EE-.....? - Follow these steps:
  1. In the Channel menu, select a number from 1 - 11 - you can choose 12 or 13, however some wireless devices don't like these channels
  2. Click SAVE SETTINGS
  3. Your settings will be applied
  4. You'll be taken back to the WIRELESS SETTINGS page.
  5. You may need to re-connect to your Bright Box 2 after making the change.
5GHz network
Wireless network name starting 5GHz-EE-.....? - Follow these steps:
  1. Select a new channel from the Channel menu
  4. You'll be redirected back to the WIRELESS SETTINGS page
Last updated: 7/2/2019
Simon H posted this. Got a comment? Good or bad, we'd be pleased to hear from you.
Was this article helpful?
  • Please select a reason
  • I didn't understand the article
  • I found the information but it didn't resolve my issue
  • Please let us know how we can make it better
0/600
Great!
Thanks for your feedback
We'll use your feedback to keep improving our help articles
