Change wireless network name
Most wireless access points broadcast their name (SSID). This is what's displayed when viewing available wireless networks and helps you to set up a wireless connection for the first time.
This article shows you how to view and change your wireless network name from your Bright Box 2 admin pages.
Open wireless settings
From a computer connected to your Bright Box 2:
  1. Go to 192.168.1.1 (opens in a new tab or window)
  2. The router's LOGIN SCREEN will open
  3. Enter the username and password for the admin pages
    - The username is admin (all lower case)
    - The password can be found on a sticker on the bottom of your router
  4. Click LOGIN
  5. The STATUS page will open
  6. Select BASIC from the menu
  7. Select Wireless Settings
  8. The WIRELESS SETTINGS page will open
  9. From here, you'll find your Wireless Network Name (SSID)
Change your wireless network name
You can change your wireless network name for the 2.4GHz and 5GHz network (you'll need to re-connect your wireless devices).
Before you start, decide if you want to change settings for 2.4GHz and 5GHz - remove the tick if you don't want to change both names:
2.4GHz network
  1. From 2.4GHz SETTINGS enter a new name into the Wireless Network Name field - we've change the name of our network to PaulsWiFi
  2. Click SAVE SETTINGS
  3. Your settings will be updated
  4. Remember - after changing wireless settings, you'll need to re-connect to your new wireless network name
5GHz network
  1. From 5GHz SETTINGS enter a new name into the Wireless Network Name field - we've changed the name of our network to PaulsWiFi2
  2. You might like to disable the 5GHz prefix also - if you do click to tick
  3. Click SAVE SETTINGS
  4. Your settings will be updated
  5. Remember - after changing wireless settings, you'll need to re-connect to your new wireless network name
Broadcast the wireless network name
If you'd prefer your 2.4GHz or 5GHz wireless networks not to broadcast their wireless network name, you can disable this option too. To change settings:
  1. Select the required option in the Broadcast SSID field
  2. In the example below we selected Disable
  5. If you disable the broadcast SSID option, you may need to change wireless settings on your device to Connect even if the network is not broadcasting (or similar)
Last updated: 7/2/2019
Was this article helpful?
  • Please select a reason
  • The article is too long
  • The article doesn't make any sense
  • Other Reason
0/600
Great!
Thanks for your feedback
We'll use your feedback to keep improving our help articles
Connect using the PIN method
Change wireless channel
