Connect using push button connect
When setting up a wireless connection, you may be given the option to push the WPS button on the router. There's a couple of examples below:
Windows 7
Windows Vista
To set up a secure wireless connection:
  1. Press and hold the WPS button on the router for five seconds
  2. Alternatively, click on the Start PBC button that you'll find in WiFi protected settings
  3. The Intelligent Wireless light on the router will flash quickly
  4. The wireless software will connect to your Bright Box 2 and set up a secure wireless connection
Last updated: 6/2/2019
Was this article helpful?
  • Please select a reason
  • The article is too long
  • The article doesn't make any sense
  • Other Reason
0/600
Great!
Thanks for your feedback
We'll use your feedback to keep improving our help articles
Connect using WiFi Protected Setup (WPS)
Connect using the PIN method
