Connect using WiFi
Your Bright Box 2 supports:
  • 2.4GHz (B,G and N) for maximum device compatibility and range
  • 5GHz (N and AC) for better wireless performance and speed (on supported devices)
Wireless settings
To connect a computer or device to your Bright Box router, you'll need:
  • Your wireless network name (also called an SSID), e.g. EE-1a2b3c or 5GHz-EE-1a2b3c
  • Your wireless password (also called a security key or wireless network key)
You'll find these on a sticker on the bottom of your router and on your KEEP MEE card:
Connect your devices
To connect, simply:
  1. Open the wireless software on your computer or device
  2. Find and select your router's wireless network name
    - If there's one starting 5GHz-EE, your device supports 5GHz wireless
    - If not, use the one starting EE-
  3. Select Connect or Join
  4. Enter your wireless password and connect
  5. Your device will now connect to your Bright Box 2
Last updated: 6/2/2019
Simon H posted this. Got a comment? Good or bad, we'd be pleased to hear from you.
Was this article helpful?
  • Please select a reason
  • I didn't understand the article
  • I found the information but it didn't resolve my issue
  • Please let us know how we can make it better
0/600
Great!
Thanks for your feedback
We'll use your feedback to keep improving our help articles
