Disable wireless security
To disable security on the router (for test purposes), follow the steps below from a computer connected to your Bright Box:
  1. Go to 192.168.1.1 (opens in a new tab or window)
  2. The router's login screen will open
  3. Enter the username and password for the admin pages
    - The username is admin (all lower case)
    - The password can be found on a sticker on the bottom of your router
  4. Select LOGIN
  5. The STATUS page will open
  6. Select BASIC from the menu
  7. Select Wireless Settings
  8. The WIRELESS SETTINGS page will open
  9. In the Security field, select the option No security
  10. Click SAVE SETTINGS
  11. Your settings will be applied
  12. Refresh your wireless software and connect using the new security details
We strongly recommend that you use this as a test only, and that you re-enable security once your wireless connection is working.
Last updated: 7/2/2019
Simon H posted this. Got a comment? Good or bad, we'd be pleased to hear from you.
Was this article helpful?
  • Please select a reason
  • I didn't understand the article
  • I found the information but it didn't resolve my issue
  • Please let us know how we can make it better
0/600
Great!
Thanks for your feedback
We'll use your feedback to keep improving our help articles
