Set up multiple WiFi network names
The Bright Box 2 supports multiple (four) wireless network names (SSIDs). This article shows you how to set up more wireless network names with separate wireless passwords and home network addresses. This is useful when:
  • You only want to give somebody temporary access to your home network - you can then regularly change the password without disconnecting all of your own wireless devices.
  • You want to keep files you've shared on your home network separate from other people.
  • You want to limit the amount of bandwidth a certain person (or group of people) can use on your home network.
Set up new wireless network name
To do this from a computer connected to your Bright Box router:
  1. Go to 192.168.1.1 (opens in a new tab or window)
  2. The router's LOGIN SCREEN will open
  3. Enter the username and password for the admin pages
    - The username is admin (all lower case)
    - The password can be found on a sticker on the bottom of your router
  4. Select LOGIN
  5. The STATUS page will open
  6. Select ADVANCED from the menu and click ACCEPT
  7. Select Wireless Settings, and then SSID Management in the left-hand menu
  8. The SSID MANAGEMENT page will open
  9. In the Multiple SSID No. menu, select 2
  10. Global settings can be left as default
  11. Enter a name for your new wireless network - in the example below we named the SSID GuestWiFi
  12. Check the option to enable Broadcast SSID
  13. Select the level of security you want for the network - we recommend WPA and WPA/WPA2 MIXED MODE
  14. For Authentication select Wireless Password
  15. For Wireless Password Type - select Passphrase
  16. Enter a Wireless Password for your new network - this needs to be 8-63 characters
  17. Optional - if you want to keep your home network separate to GuestWiFi, select VLAN2 in the SSID2 field under VLAN Binding
  18. Under 5GHz SETTINGS, you can also choose to enable settings
  19. Click SAVE SETTINGS
  20. Your new settings will be saved
  21. That's it - you can now refresh your computer's wireless software and connect to your new wireless network name
  22. You'll find you now have a standard 2.4GHz wireless network, and also a 5GHz network starting 5GHz-... if you enabled this option
Last updated: 7/2/2019
Was this article helpful?
  • Please select a reason
  • The article is too long
  • The article doesn't make any sense
  • Other Reason
0/600
Great!
Thanks for your feedback
We'll use your feedback to keep improving our help articles
Change security to WPA
Limit the bandwidth
