Connect and turn on your router
  1. Plug the other end of the grey broadband cable into the DSL/fibre port on your router
  2. Connect the two parts of the power supply together
  3. Plug the power cable into the router
  4. Connect the power supply into a plug socket and turn it on
  5. You can now switch on your router
Check it over
Everything should now look like this - the Power light will go green and the Internet light will go green shortly afterwards:
Or, if you have a dual socket, it should look like this:
Internet light off or red?
If the Internet light doesn't go green, check:
  • Broadband is live - If you're new to EE broadband, or you've moved house check your service is active by logging in to Your Account. Open the Track your orders option.
  • Your phone line is working OK - try plugging a phone into the same filter as broadband and listening for dial-tone - if not, see our guide to fixing Home Phone faults
  • Check your cables are connected correctly
  • Your Bright Box 2 is set up for Fibre Broadband. If you're on our standard broadband service, try switching settings to ADSL
Last updated: 6/2/2019
Simon H posted this. Got a comment? Good or bad, we'd be pleased to hear from you.
Was this article helpful?
  • Please select a reason
  • I didn't understand the article
  • I found the information but it didn't resolve my issue
  • Please let us know how we can make it better
0/600
Great!
Thanks for your feedback
We'll use your feedback to keep improving our help articles
