Router lights explained
Need a helping hand fixing your broadband connection? Your router's lights will point you in the right direction.
Power, Broadband and Internet green
Great news - your broadband connection is working.
The internet light flickers while the connection is being used.
Bright Box router - Power, Broadband and Internet light green
If your connection has worked before, turning everything off and back on again really does fix most connection problems.
  1. Push the ON/OFF switch on the back of your Bright Box 2.
  2. Shut down your computer (or device).
  3. Wait about 30 seconds, then turn everything back on.
  4. After a few minutes, check your connection again.
All lights are off
Check you're plugged in, and turned on. Simple.
Bright Box router - all lights are off
Broadband red
You're not receiving broadband signals.
Bright Box router - Broadband light red
Check all your cables are connected.
If you're new to EE Home Broadband or you've recently moved house, you can check your service is live by logging in to your account. You'll find more help with this in our guide track my Home Broadband and Home Phone order.
Your Bright Box 2 is set up for Fibre Broadband. If you're on our standard broadband service, try switching settings to ADSL.
Internet light flashing amber
Your router's trying to connect. After a few seconds, it will go green.
Bright Box router - Internet light flashing amber
If it continues to flash:
  • try restarting your router
  • try updating your broadband username and password on your router
Broadband light flashing amber
Your router is synchronising with broadband.
Bright Box router - Broadband light flashing amber
Wait a minute or so, then check your wiring and filter set up is OK.
Internet light red
Did you click a Disconnect button in the Advanced section of your Bright Box admin pages?
You'll now have a Connect button which you can click and get back online.
Bright Box router - Internet light red
Wireless light
Green shows wireless is enabled. A blink or flicker shows data being sent or received.
Bright Box router - Wireless light flickering
If the light is off, your wireless connection is disabled.
Intelligent wireless light
Bright Box router - Intelligent Wireless light flashing slowly
  • off - this is normal
  • flashing slowly - Intelligent wireless is searching for a new channel after the wireless button has been pressed
  • flashing quickly - WPS set up is in progress
  • solid green - a connection has been made using WPS set up
Last updated: 13/3/2019
Simon H posted this. Got a comment? Good or bad, we'd be pleased to hear from you.
Was this article helpful?
  • Please select a reason
  • I didn't understand the article
  • I found the information but it didn't resolve my issue
  • Please let us know how we can make it better
0/600
Great!
Thanks for your feedback
We'll use your feedback to keep improving our help articles
