Change admin password
You can change the password you use to log in to your Bright Box 2 from ADVANCED settings. To do this from a computer connected to your Bright Box:
  1. Go to 192.168.1.1
  2. The router's login screen will open
  3. Enter the username and password for the admin pages
    - The username is admin (all lower case)
    - The password can be found on a sticker on the bottom of your router
  4. Click LOGIN
  5. The STATUS page will open
  6. Select ADVANCED from the menu and click ACCEPT
  7. Select System and then Password Settings in the left-hand menu
  8. Enter the current password for your Bright Box - you'll find this on the sticker on the bottom of your router
  9. Enter your new password, and then re-enter to confirm
  10. Click SAVE SETTINGS
  11. Your new password will be applied
  12. You can now login to your router's admin pages using your new password
If you forget your new password, don't worry. Simply return the router to factory default settings.
Last updated: 7/2/2019
Simon H posted this. Got a comment? Good or bad, we'd be pleased to hear from you.
Was this article helpful?
  • Please select a reason
  • I didn't understand the article
  • I found the information but it didn't resolve my issue
  • Please let us know how we can make it better
0/600
Great!
Thanks for your feedback
We'll use your feedback to keep improving our help articles
