Change settings to Fibre using the Migration Wizard
You may need to use the Migration Wizard to update settings if:
  • You've already got a Bright Box 2 and are upgrading to Fibre Broadband
  • You're checking settings and they don't appear to be correct
  • You've been fiddling, and want to reset your Fibre Broadband settings (but not all your router settings)
The steps below show you how.
Log in to your router's admin pages
From a computer connected to your Bright Box 2:
  1. Go to 192.168.1.1 (opens in a new tab or window)
  2. The router's login screen will open
  3. Enter the username and password for the admin pages
    - The username is admin (all lower case)
    - The password can be found on a sticker on the bottom of your router
  4. Select LOGIN
  5. The STATUS page will open
  6. Select BASIC from the menu
  7. Open the Migration Wizard
  8. Select the Broadband type FIBRE
  9. Click APPLY
  10. Click OK
  11. Your new settings will be applied - you'll be asked to wait until your router has restarted
Check your Fibre Broadband status
  1. When your router has restarted, you'll be redirected to the LOGIN SCREEN
  2. Enter your router's Username and Password
  3. Click LOGIN
  4. The STATUS page will open
  5. After a few minutes, your Broadband Username will be updated from readytoconnect@fs to your broadband username
  6. The Broadband Status and Internet Status will display as Connected
This can take up-to 5 minutes - if you're still not connected, see our Bright Box 2 connection guide.
Last updated: 7/2/2019
Simon H posted this. Got a comment? Good or bad, we'd be pleased to hear from you.
Was this article helpful?
  • Please select a reason
  • I didn't understand the article
  • I found the information but it didn't resolve my issue
  • Please let us know how we can make it better
0/600
Great!
Thanks for your feedback
We'll use your feedback to keep improving our help articles
