Find out how to enable or disable silent mode.
- From the home screen, press the volume up or down button.
- Tap PRIORITY.
- Tap Indefinitely.
- To set a timer, tap For one hour, then tap the plus or minus icon to adjust the desired time.
- Tap the Settings icon to customize the interruptions.
- Tap Event and reminders to enable or disable events and reminders notification.
- Tap Calls or Messages to enable or disable.
- Tap Calls/messages from, then select the desired option (e.g. Starred contacts only).
Note: This option will be only available when calls and/or messages are enabled. - Tap Days to configure the desired days.
- Tick or untick the desired days (e.g. Monday), then tap Done.
- Tap Start time to configure the starting time of the priority mode.
- Tap the desired hour, (e.g. 22).
- Tap the desired minutes (e.g. 30), then tap OK.
- Tap End time to configure the ending time of the priority mode.
- Tap the desired hour, (e.g. 7).
- Tap the desired minutes (e.g. 15), then tap OK.
Note: Priority mode will by default silence almost everything, except alarms and priority interruptions.
Note: To disable all sounds, tap NONE. To disable priority mode, tap ALL.
Silent mode has been enabled or disabled.
