Add/remove widgets from the home screen
Find out how to add or remove widgets from the home screen.
Add a widget:
  1. From the home screen, tap and hold any empty location.
  2. Tap Widgets.
  3. Scroll to the required widget, then tap and hold the widget to add it to the home screen.
Remove a widget:
  1. From the home screen, tap and hold the required widget.
  2. Whilst still holding the widget, drag it to Remove and then release it.
The widget has been added or removed from the home screen.
Last updated: 23/1/2019
Simon H posted this. Got a comment? Good or bad, we'd be pleased to hear from you.
Was this article helpful?
  • Please select a reason
  • I didn't understand the article
  • I found the information but it didn't resolve my issue
  • Please let us know how we can make it better
0/600
Great!
Thanks for your feedback
We'll use your feedback to keep improving our help articles
