Set up a SIM PIN
Find out how to set up a SIM PIN on your device.
  1. From the home screen, tap the Apps icon.
  2. Scroll to and tap Settings.
  3. Scroll to and tap Security.
  4. Tap Set up SIM card lock.
  5. Tap to tick the Lock SIM card box.
  6. If prompted, tap OK, I understand.
  7. Enter the current SIM PIN, then tap OK.
The SIM PIN has been set up.
Last updated: 23/1/2019
Simon H posted this. Got a comment? Good or bad, we'd be pleased to hear from you.
Was this article helpful?
  • Please select a reason
  • I didn't understand the article
  • I found the information but it didn't resolve my issue
  • Please let us know how we can make it better
0/600
Great!
Thanks for your feedback
We'll use your feedback to keep improving our help articles
