Perform a soft reset
Find out how to reboot the device manually if you are encountering issues with the OS or applications.
  1. With the device turned on, press and hold the Power button and Volume up button for at least 5 seconds or until the device starts to vibrate.
    Note: When the Power Off option appears on screen, ignore it and continue to hold the buttons.
  2. Release the Power button and the Volume up button.
  3. The device will turn off completely.
  4. The device will reboot automatically.
The soft reset is complete.
Last updated: 23/1/2019
Simon H posted this. Got a comment? Good or bad, we'd be pleased to hear from you.
Was this article helpful?
  • Please select a reason
  • I didn't understand the article
  • I found the information but it didn't resolve my issue
  • Please let us know how we can make it better
0/600
Great!
Thanks for your feedback
We'll use your feedback to keep improving our help articles
