Connect to a hidden WiFi network
Find out how to manually connect to a hidden Wi-Fi network, just follow these simple steps.
  1. From the home screen, tap the Apps icon.
  2. Scroll to and tap Settings.
  3. Tap Wi-Fi.
  4. Tap the Wi-Fi switch to enable it.
  5. Tap the Menu icon.
  6. Tap Add network.
  7. Enter the required network SSID.
  8. Tap the Security dropdown.
  9. Tap the required security type.
  10. Tap the Password field.
  11. Enter the required password, then tap SAVE.
The connection to the hidden wireless network has been made.
Last updated: 23/1/2019
Simon H posted this. Got a comment? Good or bad, we'd be pleased to hear from you.
Was this article helpful?
  • Please select a reason
  • I didn't understand the article
  • I found the information but it didn't resolve my issue
  • Please let us know how we can make it better
0/600
Great!
Thanks for your feedback
We'll use your feedback to keep improving our help articles
