Find out how to remove an app from your device.
- From the home screen, tap the Apps icon.
- Tap and hold the required app icon.
- Drag the icon to Uninstall at the top of the screen.
- Tap OK.
Note: If Uninstall does not appear on the screen or is greyed out, the app is preinstalled and/or a system app, and therefore cannot be removed.
The app has been uninstalled.
