Wireless settings
First, we'll check your wireless settings.
  1. Click Configuration - you'll find this in the left hand menu
  2. Click Advanced and then Wireless
  3. We recommend you select WPA security only - if this is the case, move to the next section
    Livebox homepage
  4. If not select WPA security only and click Submit
    Livebox homepage
  5. Click Apply the configuration now
    Livebox homepage
  6. The configuration successful screen will be displayed - the Livebox will restart
    Livebox homepage
  7. Once the Livebox has restarted, the exclamation light will stop flashing
Last updated: 14/2/2019
Simon H posted this. Got a comment? Good or bad, we'd be pleased to hear from you.
Was this article helpful?
  • Please select a reason
  • I didn't understand the article
  • I found the information but it didn't resolve my issue
  • Please let us know how we can make it better
0/600
Great!
Thanks for your feedback
We'll use your feedback to keep improving our help articles
