Connect using an Ethernet cable
To set up a wired (Ethernet) connection between your computer and Livebox, follow the steps below:
Connect the cable
  1. Plug one end of your Ethernet cable into either the red or yellow Ethernet socket on the side of your Livebox
    Ethernet cable connected to Livebox
  2. Plug the other end into the Ethernet socket on your computer
    Ethernet cable - connecting to computer
  3. You'll hear a click when you've connected the cable correctly
Check your connection
Why not check your connection is working by going to the ee.co.uk website?
Last updated: 14/2/2019
Was this article helpful?
  • Please select a reason
  • The article is too long
  • The article doesn't make any sense
  • Other Reason
0/600
Great!
Thanks for your feedback
We'll use your feedback to keep improving our help articles
Update your broadband username and password
