Find out how to check the usage history.
- Connect the device to the PC via the USB cable or WiFi connection.
- Launch a web browser and in the address bar, enter 192.168.1.1 then click the arrow icon or press Enter.
- From the home page, click log in here to access settings.
- Enter the required username and password, then click OK.
- Click Connection Status under the Connection tab.
- Click Usage History to display usage.
- Click Clear if you would like to delete your usage history form the device.
