A Service Set Identifier (SSID) is the wireless network name broadcast by your Osprey 2 Mini. Having SSID broadcast disabled essentially makes your Access Point ‘invisible’ to devices trying to connect to a wireless network unless it already knows the SSID.
Find out how to enable or disable the SSID Broadcast.
- Connect the device to the PC via the USB cable.
- Launch a web browser and in the address bar, enter 192.168.1.1 then click the arrow icon or press Enter.
- Enter the required username and password, then click OK.
- Click the SSID Broadcast dropdown box.
- Click Enable or Disable.
- Click Apply.
- Click OK.
The SSID Broadcast has been enabled or disabled.
