Find out how to perform a master reset of your device.
Perform master reset via hardware:
- Remove the bumper to uncover the Reset button.
- Using a paperclip or pen, press and hold the Reset button for approxamately 5 seconds.
- The device will restart automatically.
Perform master reset via software:
- Connect the device to the PC via the USB cable.
- Launch a web browser and in the address bar, enter 192.168.1.1 then click the arrow icon or press Enter.
- From the home page, click log in here to access settings.
- Enter the required username and password, then click OK.
- Click System under the Settings tab.
- Click Reset.
- Click OK.
Note: Performing master reset will delete all personal configuration settings and will also restore the web-based management settings to their default values.
The factory default settings have been restored.
