Use your Hub Manager to get the best from your WiFi and manage settings:
- see all your connected devices
- see your broadband performance
- fix problems using help wizards
- access advanced settings
- change your WiFi password
To open your Hub Manager:
- make sure your Hub Manager is connected to your computer
- open your web browser on your device
- enter 192.168.1.254 or http://eehub into the address bar to access the Home screen
- to make any changes, you’ll need your admin password – it’s on the back of your Hub
To change your WiFi password:
- make sure your Hub Manager is open
- click Enter
- click Advanced settings
- click Wireless, you’II then be asked to enter your admin password - it’s on the back of your Hub
- click on the field next to Security password
- enter your new password
- click Save
Please note: if you choose an unsecure password, you’II then need to click Accept > Yes.
That’s it - your WiFi password will have been successfully changed.
