How to dim the light on your EE Smart Hub
Using the Hub Manager, you can adjust the brightness of the Hub lights. To do this:
  1. Open a new web browser on your connected device and type 192.168.1.254 into the address bar. This will open the Hub Manager.
  2. Choose Hub light control
    3. You can turn the lights off completely by setting the switch to Off or use the slider to adjust the brightness
If you want your Hub lights to switch on or off at specific times:
  1. Set Schedule to On and put in the times you want the lights to show.
  2. Choose Save.
Last updated: 20/2/2019
Simon H posted this. Got a comment? Good or bad, we'd be pleased to hear from you.
Was this article helpful?
  • Please select a reason
  • I didn't understand the article
  • I found the information but it didn't resolve my issue
  • Please let us know how we can make it better
0/600
Great!
Thanks for your feedback
We'll use your feedback to keep improving our help articles
